Sharing a little bit of my knowledge.
Putting the pumps into EOC category is a little tricky thing and requires a sound knowledge of 'System Resistance'. I would however sum up a few general scenarios wherein rating the motors for EOC is taken as a good practice.
Reasons of Operating at EOC Point
01. Auto-start pumps (Control Logic Activated & not Stand-by Pumps)
Reason: These pumps normally start with discharge valves in full open condition. Hence, the flow running through the pump is high. Therefore, the operating point shifts towards our right. But there is a catch here. We need to observe our system resistance curve. If in case our system resistance curve is 'curvy' or 'half parabolic', it is very likely that the pump's motor need not be designed for EOC operation even though our flowrate is very high. Because the point of intersection of H-Q curve and System Resistance curve may not be towards the EOC. On the other hand, if our system resistance curve is flat, we need to put the pump under EOC operation category. This is well explained by Fallah Sir in post numbered 2 and 5.
EOC operation may be necessary for sequence/logic activated Autostart pumps only. And not Standby pumps. Please note that this is an interesting debatable topic. There are contrasting views on it. But I would however suggest that auto-starting standby pumps need not be categorised as EOC operating pump. All the pumps are equipped with a non-return valve and hence, the stand-by pump shall never reach end of curve operation. Let me explain, the stand-by pump is always flooded. On the other side of the non-return valve, there would be a back pressure. When this pump auto-starts, it shall be running with a blocked outlet condition until it builds enough pressure to open the check valve. Some people are of the opinion that the backpressure is reduced to nil as soon as the running pump trips. But it must be noted that this reduction in pressure is just momentary. And hence, it should not be much of a problem.
02. Pumps operating without a discharge control valve
Reason: Same reason again. No restriction at the discharge makes the flow higher. That is to say that back pressure is lowered and this in turn makes the operating point shift towards the right.
03. Pumps in parallel operation
Reason: Parallel pumps for EOC operation is also an interesting topic. Please refer the attachment (Source: www.chemicalprocessing.com, Article: Keep Parallel Pumps Inline, Author: Andrew Stoley, Date: Feb, 13th 2008).
As we can see that the H-Q curve is flatter when both pumps are running simultaneously. If in case one of the pumps, is made to increase the flowrate, the operating point would be shifted towards the right of the FLATTER curve. Maybe the combined flowrate would not be increased to such an extent that it would reach End of FLATTER Curve. But this little shift on the FLATTER curve would mean that there is a huge shift on the STEEPER curve which represents the EOC operation of the pump whose flowrate was lesser among the two parallel pumps.
04. Pumps with Level Control:
Reason: A level change in the suction tank is also hugely responsible for shifting the curve towards EOC point. A higher level would mean lower static head on the pump. A lower static head would mean shifting of operating point towards the right of the H-Q curve.
Consequences of Operating at EOC Point
01. It would result in procurement of a motor with a high capacity. This was highlighted in post numbered 7 by Ahmad Sir.
02. It can also result in Cavitation if not taken care at the time of designing. This is because a higher flowrate (Operation at EOC point) is significantly going to increase our NPSHr, as these two are directly proportional. But this shouldn't be a problem until the Operation at EOC is momentary. A bit of sin is always allowed. Isn't it?
Edited by Lavi, 08 January 2014 - 03:11 PM.
