- ethanol
- ethylene
- water
- acetaldehyde
- acetic acid
- diethyl ether
- hydrogen
- ethane
- methane
- flash drum
- distillation column
- reactor
- fire heater
- heat exchanger
Kindly help asap... regards
Posted 20 January 2014 - 03:11 PM
Posted 21 January 2014 - 03:00 AM
Hello Aalluu.
Do you have any simulator?
I am selecting 'Electric-NRTL-RK' model in Aspenplus.
But it is difficult to set about component.
Thus, You need to find manual of electrolyte model in Simulator.
Posted 21 January 2014 - 11:43 PM
Aalluu,
Following links shall provide some information regarding which PP may be used.
http://www.google.co....59568121,d.bGQ
http://sites.poli.us...rtypackages.pdf
You may google to find out why a certain PP provides better results than other.
I tried using UNIQUAC for your system. HYSYS message window stated UNIQUAC doesn't have BIP's for a few components.
When I selected PR, it says it's not recommended for a few components.
PRSV did not indicate any error.
I would recommend you study this topic further through literature. It will take time, but it is worth it.
You may also contact AspenSupport team to provide you with ready-made answer.
Most people I know in this business (including myself) trust Hysys results, only if the results match with some reference system.
All the best.
Regards.
Ajay
Posted 26 January 2014 - 01:29 PM
hi aalluu
u can take help from your mentor for your project. anyways their is fluid package selection assistant in aspen plus that can be used.
anyways whatever method you adopt, do inform us in the end. That would be quiet helpful for all.
best of luck
Abubakar Sohail
Selection Type Of Heater For Refrigerated PropaneStarted by Guest_livetolove003_* , 07 May 2025 |
![]() Recommended Fluid VelocityStarted by Guest_crn_* , 16 Apr 2025 |
![]() Supercritical Fluid Flowrate - He Tube RuptureStarted by Guest_flarewolf_* , 07 Apr 2025 |
![]() Activated Carbon SelectionStarted by Guest_Talhafarooq_* , 25 Nov 2024 |
![]() Selection Of Type Of Pumps For "negative" Npsha And Solution TStarted by Guest_linda_pro_* , 29 May 2024 |
