Hi May I know what the field 'service' means in an equipment data sheet and where will i be able to find it?
ChemEng Student
Posted 28 January 2014 - 10:33 AM
ChemEng Student
Posted 28 January 2014 - 11:34 AM
Service is simply what the equipment is doing; what its name is.
For example: service of a pump can be: Fractionator Reflux Pump or Cooling Water Pump or .....
service of a heat exchanger can be: Reactor Feed/Effluent Exchanger or Debutanizer Reboiler or .....
![]() Best Practices For Handling 50% Hf – Equipment Failures IssueStarted by Guest_Jaydip_* , 19 Jun 2025 |
Higher Pipe Line Dia Specification In UnisimStarted by Guest_Praveen Perumandla_* , 27 Feb 2024 |
Dry Coolers Data SheetStarted by Guest_Quimarah_* , 03 Sep 2023 |
Equipment Spec SheetsStarted by Guest_Ken Bicknell_* , 07 Jun 2023 |
Heat Losses Of EquipmentStarted by Guest_panoska_* , 20 Oct 2022 |
