Fallah
The issue is this:
I need to determine whether with the current operating conditons, the PSV installed is adequately sized to handle the flow. Three methods I am looking at:
1. Assume the tank contents is hexane and apply Table 6 of API 2000 for a wetted surface area greater than 2800 ft2. I'm assuming the tank is at it's maximum capacity. This gives me a relieving rate which is greater than the rated.
2. A hysys stream is used to define the condensate which is then heated in a tank at its maximum capacity with a heat input (14,090,000 Btu/hr). This method gives me a total vapour stream with no liquid flow out the bottom. Equation 12 of API 2000 is applied and the latent heat of vaporisation is taken from the inlet condensate stream. This results in an adequately sized PSV.
3. A constant heat interval method was used. Here, heat is added to a series of tanks in 20 min intervals until the maximum outlet vapour flow rate is achieved. The tank volume changes as vapour is lost and so the heat input then depends on the new wetted surface area. I see from using this method that the outlet flow rate is dependent on the flow rate of the initial inlet condensate stream. The relieving rate was above and below the rated for different inlet condensate flow rates.
Please see the general hysys layout attached.
Edited by Nicholas, 07 February 2014 - 08:32 AM.
