Flash Gas Generation In Mdea Sweetening Unit
flash gas generation in mdea
#1 apex
apex
  • 25 posts
Posted 17 February 2014 - 09:51 AM
In my MDEA sweetening unit the flash gas generation is 6-7 times more than what I get from simulations of the unit (hysys & pretreat). We recently installed a new unit & in this unit this flash gas generation was high initially but subsequently it has come down drastically & is around 1.5-2 times of the simulated value. I had a talk with a consulting firm & they said that for design purpose they used to multiply the simulation value by a factor of 5. Can anyone throw some light on the solubility of light hydrocarbons in generic MDEA & amount of flash gas generation in MDEA sweetening units.
natural gas composition & FLOW:                              OUTLET GAS :  H2S< 4 PPMV
 6.3 MMSCMD     TEMP- 35 C                                    CO2 -- MAXIMUM SLIPPAGE
C1--- 80 MOL%                                                  MDEA ENTERING ON 9TH TRAY HENCE 5 TRAY IN
C2------7 MOL%                                                   OPERATION.
C3---- 4.3 MOL%                                                 CONTACTOR----- VALVE TRAY COL (14 TRAY)
IC4---- 0.8 MOL%                                                 REGERATOR -----VALVE TRAY COL (21 TRAY)
NC4---- 0.8 MOL%VALVE
IC5----  0.4 MOL%                                              CONTACTOR PRESSURE- 60 KG/CM2G
NC5---- 0.3 MOL%                                              REGERATOR PRESSURE-1.1 KG/CM2    TEMP TOP - 105 C
C6+ ---- 0.2 MOL%        TEMP BOT - 129 C
CO2 --- 6.2 MOL%
H2S ---- 200 PPM                                              FLASH DRUM PRESSURE - 8 KG/CM2 G
#2 gegio1960
gegio1960
  • 518 posts
Posted 17 February 2014 - 10:48 AM
where is your flash? (it should be upstream of the absorber)
real flowrate is either 6-7 or 1.5-2 times more than the simulated figures?
which is the destination of the flashed gas?
which is the destination of the sour (stripped) gas?
#3 apex
apex
  • 25 posts
Posted 17 February 2014 - 11:24 AM
Flash is downstream of absorber & flashed gas is used as fuel gas . the sweetened gas is sent to dehydration unit for water removal.
#4 apex
apex
  • 25 posts
Posted 17 February 2014 - 11:27 AM
we have 9 units .out of which 7 are in operation. in 6 units the flash gas generation is very high while in the recently installed unit the flash gas generation is near to the simulation value.
#5 RockDock
RockDock
  • 257 posts
Posted 03 March 2014 - 11:02 AM
can you post the output reports for Hysys, ProTreat and the operating data?
Do Hysys and ProTreat agree with one another? Or do they have different predictions?
I think there may be a good explanation, but I will need to have a closer look.
