By-pass Valve Around A Nrv Of A Pump Discharge Line
16 replies to this topic
#1 Pronab
Pronab
  • 166 posts
Posted 24 March 2006 - 10:08 AM
In a small pump arrangement (LT motors); we have always a stand –by pump to give a facility: auto start in case of the running pump failure.
Discharge line of the pump contains a NRV (non return valve) followed by a globe valve. And there is a small by-pass valve around the NRV and the globe valve. During normal operations of the pump, this small by-pass valve kept close with blinded, as showing in the P&ID. This by-pass valve is not for equalizing the discharge line as pressure difference between suction and discharge is very low( from 4 to 6 barg). But I don’t understand why this small valve should be in closed condition rather than crack open to give a little flow from the running pump so that stand-by pump casing and piping’s will be in warm condition at all the time, keep ready in case of the running pump fail. (Suction fluid temperature of the pumps vary from 55 to 110 deg. C.)
Is my idea correct? Any comments are highly appreciated.
Best Regards.
Pronab.
#2 Pronab
Pronab
  • 166 posts
Posted 24 March 2006 - 01:34 PM
By mistake it appears on the STUDENT page, it should be on professional item.
Pronab.
#3 Art Montemayor
Posted 26 March 2006 - 01:49 PM
Pronab:
For a while there, I thought an old Pro like you had gone back to University when I saw this thread in the Student Forum. I'll give some comments here because I believe this is a great, practical subject for all student engineers to become familiar with and study the application.
From what you describe, I had to generate a quick Excel sketch in order to make sure I know what centrifugal pump arrangement you have. I assume you have centrifugal pumps.
From the attached sketch, I am assuming that I have depicted your installation correctly; if not, please correct me. I believe the small, by-pass valve(s) that are around the check valve and the discharge block valve only serve to act as manual priming devices for the stand-by pump or the running pump. The priming fluid would be the fluid left over in the discharge line. Otherwise, I see no need for the by-pass valve.
Because you haven't identified it, I have had to assume the operation of putting the stand-by pump into operation (while shutting down the running pump) would be manually done. That would explain the by-pass valve. Under the illustrated piping configuration you can see that the check valve is preventing any self priming by the pump from the discharge side. There are various ways to manually prime the stand-by pump and one of the simplest ways is to vent the top of the casing (usually back to the suction tank vapor space – not shown in my sketch) and open the by-pass valve to allow discharge fluid to flow through the casing and back to the suction tank. Once the casing is full of liquid, the by-pass and the vent valve are closed and the pump’s suction block valve is opened. The pump can now be started under primed conditions and should pump immediately.
If you have totally instrumented and automatic start-up of the stand-by centrifugal pump, then you require automatic-controlled by-pass valves operation as well as the inlet and discharge valves. Otherwise, the system won’t shut down one pump and startup the other one. By the way, what is an “LT” motor?
I can understand your concern for trying to keep the stand-by pump warm while it is sitting there idle, but from what you describe, the by-pass valve contributes little or nothing to keeping the stand-by pump warm or hot. In order to keep the stand-by pump under process temperatures at all times, you need to trace the pump with steam or electrically on the outside surface of the casing. You can direct the discharge of one pump into the suction side of the stand-by and let the hot fluid discharge of the running unit go through the idle stand-by, but this will cause a pressure drop (beside spinning the impeller of the idle stand-by. The best, simplest way is to keep the stand-by pump heat traced at all times. This method avoids a lot of complicated piping arrangements and configurations. If you have jacketed pump casings (which is a high probability in the case of hot fluid pumping), then you can run the discharge of the running pump through the jacket of the stand-by pump.
You also have not explained if you are alternating the service of these pumps. For example, in the actual industrial case where it is highly important to have back-up pumping capacity at all times, the usual practice is to have the running pump assume the role of “stand-by” after it has been shut down and replaced by the stand-by unit. This implies that both pumps should be regarded as “stand-bys” and, therefore, should be piped and instrumented almost identically in every respect.
I hope these comments and response help to explain the installation.
Attached File  Standby_Centrifugal_Pump.xls   25.5KB   471 downloads
#4 Pronab
Pronab
  • 166 posts
Posted 29 March 2006 - 11:18 PM
 I acknowledge earlier, by-mistake it appears in the STUDENT FORUM instead of professional forum.
 You are right; I am talking about centrifugal pumps.
 Definitely it is not used for priming or draining the pump. For priming there are valves in the pump’s casing: from top and bottom. After priming we kept the pump as STAND-BY so that it will start in auto, in case of running pump trip (trip signal activate to start the stand-by pump).
 Stand-by pumps are not started manually, always start in auto, I mention earlier.
 LT motors mean low tension motor, where power supply is 415 V.
 For test case we keep this small by-pass valve little open, found casing of the pump become warm. If discharge line NRV passing, pump will start reverse rotation (by-pass line is small compare to discharge line size, so that it will prevent reverse rotation).
 Keeping this by-pass valve little open, running pump amp and discharge pressure change very little. It is not remarkable.
 We have pumps those having steam tracing, handling fluid which need a certain temperature to prevent solidification at low temperature. It is handling liquid sulfur.
 Yes we do. We change over these types of pumps to check its reliability at regular intervals.
 I can not open your attachment. Can you attach it again.
#5 sachin arora
sachin arora
  • 3 posts
Posted 12 April 2006 - 06:53 AM
hi,
i am a new young member .
want to comment for ur question
if u make ur Q a bit more clear with some line diagram
#6 joerd
joerd
  • 371 posts
Posted 12 April 2006 - 09:18 AM
QUOTE (sachin arora @ Apr 12 2006, 05:53 AM) <{POST_SNAPBACK}>
hi,
If you could spell properly, we might be able to understand what you mean.
Read Art Montemayor's post including the attachment.
#7 sachin arora
sachin arora
  • 3 posts
Posted 12 April 2006 - 11:32 PM
QUOTE (joerd @ Apr 12 2006, 09:18 AM) <{POST_SNAPBACK}>
hi,
i just want to ask you that weather you are talking of an change over valve or of an by pass arrangement
#8 Guest_Guest_*
Guest_Guest_*
  • guestGuests
Posted 13 April 2006 - 10:55 AM
QUOTE (sachin arora @ Apr 12 2006, 11:32 PM) <{POST_SNAPBACK}>
hi,
#9 Pronab
Pronab
  • 166 posts
Posted 13 April 2006 - 11:24 AM
Reply to sachin
Here I attached a drawing for the by-pass valve arrangement.
Pump discharge non-return valve by-passare used for the following criteria( which is the requirements of our company General design specifications):
 Pump is spared with common suction and discharge lines.
 Discharge and suction line design temperatures above 230ºC.
 Process fluids that can solidify at ambient temperature (e.g., heavy hydrocarbons).
 Cryogenic service or fluid temperature considerably below ambient temperature.
Not change over. I want to know , should I keep this valve little open all the time.
#10 Guest_Guest_sachin_*_*
  • guestGuests
Posted 14 April 2006 - 11:26 PM
QUOTE (pronab @ Apr 13 2006, 11:24 AM) <{POST_SNAPBACK}>
Reply to sachin
hi , i think by keeping it little open you will be allowing the pressurised water go back to the impeller of the stand by pump and hence will require to provide an NRV at the suction end of the pump , othervise it will start going back in that line .rest of all yr concept is brilliant . any comments will make me learn more.
thanks for taking out your precious time for sending me that diagram
sachin arora
#11 Guest_Guest_afdmello_*_*
  • guestGuests
Posted 16 April 2006 - 05:08 PM
Pronab,
Regarding the small bypass line provided on the discharge to suction of pumps is actually called a "warmup line"and the valve is crack open to permit fluid from the discharge of the running pump to flow thru the standby pump and into the suction lines.
You are right. You need to keep the valve crack open.Kindly study the pump characteristics and the pump manufacturers manual to check the minimum operating temperature of the process fluid to maintain the mechanical integrity fo the pump.
We have double suction high volume hot water( saturated water) pumps with a similar layout even though they are not auto start.
Operating conditions : suction :6barg ;discharge :30barg; Suction pipe dia :10"; warmup line dia : 1/2".
We also have similar arrangement on a high pressure boiler feed water pumps which are of auto start on low discharge pressure.
HTH
Afdmello
#12 Pronab
Pronab
  • 166 posts
Posted 18 April 2006 - 08:43 AM
QUOTE (Guest_afdmello_* @ Apr 16 2006, 05:08 PM) <{POST_SNAPBACK}>
Pronab,
HTH
Afdmello
To Sachin
To keep little open of this by-pass valve, we didn't find any problem for a short period of time( to check the condition we open it for some hours). I don't think, we need any NRV in suction line.
To HTH
This by-pass is arround the NRV and discharge valve of the Pump(please have a look on the attach drawing), not arround the discharge to suction, and it is not a warm-up line. This by-pass line dia.: 1/3 ".
I don't see any such types of valve in the high discharge pressure pump.
Pronab.
#13 Guest_Guest_*
Guest_Guest_*
  • guestGuests
Posted 21 April 2006 - 04:33 PM
QUOTE (pronab @ Apr 18 2006, 08:43 AM) <{POST_SNAPBACK}>
To HTH
Pronab.
I have no dispute in you wanting to call this 1/3" line whatever you want to. I saw your attachment and appreciate the time taken to do it in MSword when MS visio would have been a better option.We just have a similar set up as in the drawing and the valve is kept crack open always of the standbypump to maintain a small discharge flow from the discharge thru the pump casing and into the suction.Besides this type of service is very common in refinery cdu/vdu sections
Go ahead and choose whatever is best for your setup.
AFD
#14 Pronab
Pronab
  • 166 posts
Posted 23 April 2006 - 03:18 PM
Dear AFD
I need specific reference to change. In P&ID it shown blind, which I need to open.
Without any strong reference I can not do this. If you have, please pass it.
Thank you for your attention.
Regards.
Pronab.
#15 joerd
joerd
  • 371 posts
Posted 24 April 2006 - 11:00 AM
Pronab,
The purpose of the valve is (usually) as stated by AFD. The blind is there to give positive isolation if you want to remove the pump. You probably have a blind at the check valve as well. Both need to be turned (closed) before you take away the pump. When the pump is installed, the blinds can be opened again.
#16 Pronab
Pronab
  • 166 posts
Posted 24 April 2006 - 11:34 PM
Joerd
The blind, shown in P&ID, is normally closed condition and when necessray can turn in open condition.
There is no blind in NRV. But there is provision for blind for positive isolation OF THE PUMP. If normal practice for the by-pass valve is open then blind should be shown in open condition in P&ID.
Thank you for your time.
Regards.
Pronab.
#17 joerd
joerd
  • 371 posts
Posted 25 April 2006 - 10:25 AM
That is why we always show them open in this arrangement. There may be two possibilities:
1. It is intentional. I can only guess why (for example to prime the pump - many suggestions have been given earlier in this thread).
2. It is a drafting error. This does occur, process engineers and draftsmen are only human.
