I am a process engineer with one year experience.There is a 3 phase horizontal separator and has got both BDV & PSV. The operating pressure ranges from 30 to 110 kg/cm2 (g). The design pressure is 203.3 kg/cm2 (g). The initial pressure considered for BDV Depressurization (Depressurization tool in Hysys) is the PZHH of the separator, i.e 121 kg/cm2 (g). The PSV is set at 150 kg/cm2(g) (usually PSV set pressure will be the design pressure, but here in order to protect the downstream facilities which is designed at lower pressure, the PSV is set at 150 kg/cm2(g).)
As per my understanding, BDV being the primary protection for the separator, when fire occurs, BDV opens and evacuates the inventory and the BDV is kept at open unless it is reset. The pressure drop is achieved across the RO and relieved to flare. So if BDV operates correctly, PSV will not pop up.
PSV will act only if the primary protection fails (BDV fails to open).
Kindly advice on my above understanding.
Whether the initial pressure of 121 kg/cm2(g) (PZHH of the separator) selected for depressurization is correct with respect to PSV set pressure of 150 kg/cm2(g)?
During fire, is there be a possibility of both BDV & PSV opening simultaneously?
