Hi all,
I'm a new process engineer just recently graduated from university. I really like to read from this site as it really helps my day to day work. I'm stuck with my current work so I think posting the question in this site would help me.
I have a question regarding PSV calculation for pressure vessel in offshore platform. The normal operating pressure is about 100 barg, but the design pressure is 300 barg (designed to withstand wellhead shut-in pressure). In normal condition, there is a liquid level at the vessel.
The only scenario considered is fire case. When the fire starts, the liquid will begin to boil. As the design pressure is so high, the liquid will continue to boil until it becomes supercritical. After that it still needs to build pressure before reaching the set pressure of the PSV.
My questions are :
1. Due to high relieving pressure, the relieving temperature is also very high. In fact it exceeds API 521 recommended wall temperature. As such can we discard the PSV using this assumption? Note that our local code dictates every vessel for having a PSV. Is it imperative to follow the code regardless the relieving condition?
2. If the PSV cannot be omitted, which equation should we use to calculate the relief load and relief area? My understanding is that at supercritical condition, we shall use API 521 equation for vapor filled fire case to calculate both the relief load and relief area. But there are also different views of my colleague that because originally there is a liquid inside the vessel, we should use equation for fire case liquid filled using minimum value of latent heat (115 kJ/kg) to calculate the relief load and use HEM method to calculate relief area. Other comment is that we should use volume expansion method explained in API 521 6th edition to calculate relief load. Which one do you think is correct?
Sorry if it's too long, hope that I explained the problem clearly.
Thank you in advance!
