I need your guidance in the subject matter. We are working on one proposal of crude oil processing facility. we have FEED data with us and in that well fluid compositions are given. crude is relatively heavy crude with API density ranges 16° - 19°. In this case, client has not provided crude oil ASSAY in terms of D86 or TBP data, instead given component wise mole fraction including C31 to C36+ hypo components property to generate in hysys. Attached below is the input data that we have received from client.
Since I am new in characterizing HEAVY oil in hysys, i am not sure whether the data given in attached spec for hypo component are sufficient to generate accurate hypo C31 to C36+ component. The reason I am asking is, when i genrated hypo based on the data given in attachment and generated the stream in hysys inputing all the individual component composition. I am getting very weird result in hysys. I am getting density below 1 at specified pressure and temperature.
my questions mainly are
1) Is data provided as attached is sufficient to model crude oil accurately in hysys. if yes, where am i goofing ? I have used peng robinson thermo model.
2) Is there anything special consideration to be given to characterize HEAVY oil in hysys. The crude which is in question in our case is having API gravity range as 16-19°. crude is sweet (no H2S).
