Flue Gas Desulphirization - Sprayer Installation
#1 Student127739563
Student127739563
  • 4 posts
Posted 13 March 2014 - 06:45 PM
Hi guys,
I'm wondering if any one has any experience with sprayers for scrubbers, specifically a Flue Gas Desulphurization unit. I'm looking to cost out the installation of a new layer of sprayers for a FGD unit, job by job, as well as the time required per job, but I am unfamiliar with what sort of work would be associated with this task (ex. erecting scaffolding inside the vessel, welding nozzles on pipes, etc.). Hopefully someone can give me some insight about this if they have any experience.
#2 Santoshp9
Santoshp9
  • 61 posts
Posted 13 March 2014 - 11:14 PM
Dear GM,
What are dia,height,handhole manhole dimenssions of your existing scrubber?.
Also tell about your gas flow,temp,pressure,composition,RC flow of slurry (Calcium or NaOH based),so that we can guide you how to utilize your existing system or whether it is suitable for your existing one.
Santosh
#3 Student127739563
Student127739563
  • 4 posts
Posted 14 March 2014 - 01:53 PM
Hi Santosh,
I have calculated the vessel dimensions to be H ~ 52m, D ~ 18 m.
Other specs. on the system are as follows:
T (flue gas in) = 330 deg. F
P (in) = 6 in. H2O
M total, flue gas in = 5 x 10^6 lb/hr
M H2O, in = 2 x 10^5 lb/hr
M SO2, in = 2.25 x 10^4 lb/hr
V gas, in = 3.1 m/s
90 % SO2 removal required
Slurry is CaCO3 based, 30 wt. % CaCO3 w/ L/G ratio of 17 L/m^3.
I'm looking to know what kind of work would need to be done to fabricate/install/implement, etc. a new layer of sprayers for this column.
For ex. weld nozzles on distributor pipes, bring pipes in through man-door, erect staging inside scrubber, etc etc.
Any help about this is greatly appreciated.
#4 Santoshp9
Santoshp9
  • 61 posts
Posted 17 March 2014 - 12:55 AM
It's simple by erecting scaffolding & take in n out material from man door which is possible to fabricate outside the vessel & can be put easily inside through man door.
Santosh
