Hello all,
I have a mixture of ammonia + water composition inputed in Hysys and I want to find out know what's the freezing point of this mixture.
How can I find the freezing point in Aspen Hysys ?
Tank you.
Posted 19 March 2014 - 03:16 AM
Hello all,
Tank you.
Posted 19 March 2014 - 04:54 AM
For Dew point and cricondertherm temperature of the same you may add Envelope utility on specific stream.
Posted 19 March 2014 - 06:02 AM
liquid-solid or vapor-solid equilibria requires a specific multiphase capability,
see for example
http://www.prode.com/en/multiphase.htm
I have calculated freezing points for water + glycols with Prode
but to reduce errors you need to tune the model
for liquid fugacity usually it's a EOS or a model based on liquid activity as NRTL or UNIQUAC
as alternative you may consider the tables of values available for many mixtures as water + ammonia
Posted 20 March 2014 - 03:11 AM
Ok, thank you.
