Degree Of Freedom For Distillation Column
#1 DANA-IF
DANA-IF
  • 160 posts
Posted 24 March 2014 - 03:27 AM
Hi friends :)
 Why In hysys once degrees of freedom becomes zero we can run column and get the results ,
As I know every system has its calculated degree of freedom
#2 Said Salim
Said Salim
  • 98 posts
Posted 24 March 2014 - 05:33 AM
Hi N.BH
I think you have answered your self zero degree of freedom implies that you have defined all the parameters to run the system
In this case you have defined all required parameters of DC system
#3 equilibrium
equilibrium
  • 22 posts
Posted 31 March 2014 - 10:31 AM
The real question should be what degrees of freedom can and should be used for a column.
