Acid/base Neutralisation Control
#1 RaoulM
RaoulM
Posted 24 March 2014 - 05:32 PM
I am working on the design of a neutralisation process in a batch tank. The operators/owners would like to run the tank at a low liquid level and add acids to a neutral or basic solution. They would like to monitor temperature and if there is any indication that the temperature gradient is too steep (indicating excessive reaction) they would like to add unmetered quench water to cool and dilute the reaction. This would be controlled by a simple on/off solenoid valve. When the temperature is back in the acceptable range, the water is stopped. The proposed operating liquid level is around 10% of the total volume. There should also be a high level switch present to raise a LAHH alarm and stop the water.
My concerns are around this as a valid control scheme. If the temp is still rising and the TIC calls for water AND the level is high enough to trip the LAHH, then surely I have to set a priority.
One option is to run the solution through a cooling HX, but I am concerned about undissolved solids building up in tubes or plates. Sufficiently cold water is not available to be able to use internal tank coils and the tank will be fibreglass so jacketing is not an option.
Any suggestions on whether the proposed scheme is workable?
Raoul
#2 sukanta87
sukanta87
  • 90 posts
Posted 27 March 2014 - 03:36 AM
Hi Raoul,
I think your control system must be sufficient and logical for better quality and smooth operation. You can think about PID controller instead of ON/OFF SDV.
To control the temperature in the neutralization tank cooling jacket can be used instead of direct water intake into the tank.one single loop temp controller can be implemented for the controlling.
To control both pH and level in the tank, a cascade control system in the acid line can play desired performance.The master controller should be level controller and slave controller should be pH controller.
