Hi friends
Iid like to know how to have the enthalpy of air (Hin , Hout) from air cooler simulation on hysys or how to calculate
them ?
Posted 08 April 2014 - 09:18 AM
Hi friends
them ?
Posted 08 April 2014 - 10:16 AM
do you know tin, tout ?
then you can calculate enthalpy difference assuming constant cp
enthalpy of stream = specific heat * (T-Tref) * mass flow
see for example
http://www.engineeri...res-d_1535.html
as alternative you can use the simulator to export the values of enthalpy in different streams,
you may for example export in Excel, I do that with PRODE and
macro StrH() which returns directly the enthalpy of a stream,
for example if stream 1 is the air to air cooler and stream 2 the air
from air cooler your value would be =StrH(2)-StrH(1)
Posted 09 April 2014 - 08:25 AM
Hi thank you, but the equation
gives a unit : kcal /hr
I'd like to have mass enthalpy with Kcal /kg
I found this link , it is very useful, you just have to input temperature and pressure of air
http://www.peacesoft...rte/luft_e.html
then you click on calculate and you will have calculated properties
Posted 09 April 2014 - 10:30 AM
N.BH wrote
the equation enthalpy of stream = specific heat * (T-Tref) * mass flow
gives a unit : kcal /hr I'd like to have mass enthalpy with Kcal /kg
you can calculate specific enthalpy as specific heat * (T-Tref)
