hello everyone,
could anyone help me how to calculate natural draft furnace efficiency. Any help would be appreciated.
thank you.
Posted 13 April 2014 - 08:19 AM
hello everyone,
thank you.
Posted 13 April 2014 - 10:22 AM
Why don't you try first, and let us see your methods and results. It should not be too difficult for you to find the proper method. Start with Google.
Posted 13 April 2014 - 01:07 PM
nishartril
It depends on your purpose of the calculation. If the calculation is for design a furnace, the calculation will be much more complicated. If you want to figure out the efficiency of an existing furnace, the calculation step shall be as following:
1. Heat input
Heat input will be from fuel. To complete the heat input you need to know fuel composition, temperature, flow rates and LHV for each composite - reference to API 560.
2. Heat used to heat the medium
Medium inlet and outlet temperatures, specific heat capacity and flow rate.
3. Calculate the efficiency of the furnace
Heat used to heat the medium/Heat input*100
Hope this help
Posted 13 April 2014 - 09:41 PM
This paper may help you .
Good luck,
![]() Maximum Natural Gas Flow Through OrificeStarted by Guest_ukrche_* , 10 May 2024 |
Heating Of Natural GasStarted by Guest_kaidlut_* , 01 May 2024 |
Chiller Efficiency Dependence On Cooling Water TemperatureStarted by Guest_Neha Vensiyani_* , 29 Apr 2024 |
Tank Blanketing With Natural Gas/ Vapor Recovery SystemStarted by Guest_MethanolPlant_* , 26 Apr 2024 |
Conversion Of M3 Of Natural Gas To M3 Of LngStarted by Guest_sachico28_* , 30 Sep 2023 |
