Dear all,
why we cannot use the Schultz method but only by Reference method(Huntington) when calculating the the efficiency or polyropic head of a compressor?
Sacarove
Posted 25 April 2014 - 02:32 PM
Dear all,
Sacarove
Posted 26 April 2014 - 04:31 AM
Sacarove,
Why is your post titled "wet gas compressor"? Do you want to compress wet gas - that is, a gas-liquid mixture?
Paul
Posted 26 April 2014 - 08:46 AM
for wet gas you need to solve H, S , phase equilibria,
you can't with both Schultz or Huntington (see the original papers for the details about these methods),
with the so called reference method you can only estimate final conditions when there is a liquid phase
(at each step the procedure estimates the amount and composition of vapor),
much better to use a specific method which is applicable to both vapor and liquid phases,,
see for example the method PSPF() in Prode Properties
http://www.prode.com/docs/pppman.pdf
Posted 28 April 2014 - 03:41 AM
Hi Marchem,
Thank you very much.
Do you know how much this prode deviates from hysys if I have a gas fraction not less than 95%?
Sacarove
Posted 28 April 2014 - 04:37 AM
typical liquid amounts are well below 5% for standard compressors to avoid mechanical damages,
if you are working on some subsea pumping station then use the method in Prode Properties which
can work with ANY liquid amount (up to 100% liquid).
Compressor Selection Based On Flowrate & Compression RatioStarted by Guest_Dhams_* , 19 Jan 2026 |
Purge Gas For Centrifugal CompressorStarted by Guest_Lyne_* , 19 Oct 2025 |
