process calculation of multiple effect evaporator
Process Calculation Of Multiple Effect Evaporator
Posted 07 May 2014 - 06:30 AM
Posted 07 May 2014 - 07:40 AM
Posted 08 May 2014 - 04:55 AM
Thank you Breizh
This is very useful.
Posted 08 May 2014 - 07:06 AM
Breizh:
Thank you very much for yet another great engineering contribution. This is particularly interesting to me because it is a presentation by Dr. David Clough of the University of Colorado. Dr. Clough has been a pioneering advocate of employing computer programming - especially the use of Excel spreadsheets and VBA - into chemical engineering problem solving and calculations - something that I have been preaching for many years. He has a glowing reputation as a teacher and as a past industrial engineer when he worked for DuPont. He writes great stuff and expresses his logic in his calculations.
Posted 08 May 2014 - 08:01 AM
Nidhi,
I have developed a spreadsheet earlier on when i started in 2011. see attachment. comments and suggestions will be welcome. what i did most of the time was to give the vendor initial concentration, target product concentration and the steam available. the vendor does the rest. i used this spreadsheet to kinda double check the vendor quote.
thank you,
Posted 08 May 2014 - 08:21 AM
Pingue2008:
Good contribution of a professional-quality calculation(s). Not only is the presentation clear, there is no need to check the arithmetic. All one has to do is follow the clear logic of the algorithm. This reflects great training and preparation. Good work.
Posted 08 May 2014 - 11:05 PM
Spreadsheet is very useful..
Thank you.
![]() Strategy For Adequacy Check Of Multiple Bdvs In A SystemStarted by Guest_nabeelsp1036_* , 22 Jan 2025 |
Going Through The Writing Process.Started by Guest_Haywardvek_* , 05 Jan 2025 |
Typical Process Of Platformate Splitter ?Started by Guest_AnbIran_* , 30 Dec 2024 |
