I am looking for density gal/Ibmole at 14.696 psia , 60 F for gas mixtures from C1 up to C7+ .Anyone can guild me where I can find it? I would like to calculate liquid volume for gas mixture.
Appreciate your helps.
Posted 08 May 2014 - 03:20 AM
Posted 08 May 2014 - 04:14 AM
Gas Densities in USC units are defined as lb/ft3. To calciulate the densities, you need to know the molecular weight of the gas mixture. Refer the link below on how to calculate gas densities at either standard conditions of 14.696 psia / 60°F or at any other conditions of pressure and temperature:
http://www.cheresour...ard-conditions/
Posted 08 May 2014 - 05:52 AM
Thanks you very much this really helpful .
Posted 08 May 2014 - 09:24 AM
You write that you want to calculate the liquid volume of a gas mixture ranging from methane to heptane.
The only way that I know how to do that is to employ an equation of state (Peng-Robinson, for example), a simulation program, and a dewpoint calculation. This is a phase equilibria type of calculation where you know:
1) the molecular weight of each of the gas components;
2) the mole composition of the gas mixture.
What you don't know is:
a) at what pressure and temperature does the mixture liquefy (dewpoint) - if it does;
b) what is the density of the resulting liquid product at the saturated liquid conditions.
You tell us that you want the liquid density at 14.696 psia & 60 oF but it is probably not possible to have a liquid product (presumably at saturated condtions) at those condtions. --But then you don't tell us what you need the information for or what you intend to do with it.
Posted 08 May 2014 - 11:46 AM
There is something called GPM, (gal. NGL per thousand std. cubic feet of gas), in the natural gas processing business. Check how this is defined; maybe this is what you are looking for.
Posted 08 May 2014 - 01:58 PM
Art/Bobby , first , thanks you for respond ,appreciate your help and support .
Why I am asking about density because I have seen post here in our forum about NGL yield calculation excel sheet which was mention density in gal/Ibmole and I was reviewed GPSA book where they did mentioned density in Kg/m3. However , this confused me from where this density come from? dose this was given as standard at that pressure and temperature or there is calculation behind it .However, if it given as standard how I can obtained actual density for each respective component at different pressure and temperature. Also how I can converted from kg/m3 to gal/Ibmol in order to get estimated NGL recovery .
Posted 08 May 2014 - 03:52 PM
Look for the definition of GPM with Google and you will find the answer. Here is one.
http://www.composis....nt/free/mol.htm
Edited by Bobby Strain, 08 May 2014 - 05:29 PM.
Posted 09 May 2014 - 06:52 AM
Bobby, thanks you for a very useful link ,however, they did not specify from where gall/Ibmole coming from?or how they did calculate ?
Posted 09 May 2014 - 09:57 AM Best Answer
Graduate:
Bobby was perfectly correct in his response and assumptions.
I specifically stopped from going any further in probing just exactly what it is that you need or require because I expected you to respond to my comment: "...you don't tell us what you need the information for or what you intend to do with it." I want to make a point here before giving you the precise information I think you require: as a young graduate you would be well advised to communicate your needs and requests in a direct, specific, and detailed manner. Otherwise, experts (like Bobby) are left to guess, speculate, or ponder just exactly what it is that you are talking about. And this wastes a lot of our member's valuable time and efforts.
Now to get to your need. I believe now that you require knowledge about the GPSA and the excellent Engineering Databook that they publish. If you are interested in following up on this recommendation, ask us about it. For now, read the excerpt I have taken from said Databook and that should satisfy your request. I hope this helps you out - but you need to work on your communicating skills.
Posted 09 May 2014 - 10:32 AM
Understanding Polytropic Head And Its Relationship With Gas DensityStarted by Guest_Kakka_* , 18 Dec 2024 |
Separation Technology For Separate / Distillate Hcl From Water MixtureStarted by Guest_dpunnn_* , 11 Sep 2024 |
![]() Prv Fire Case Load Calculation For Mixture.Started by Guest_Halflight_* , 24 Jun 2024 |
How To Find K-Values Of A Hydrocarbon Mixture On Aspen Hysys?Started by Guest_Alexis Azamar_* , 08 Apr 2024 |
![]() ![]() How To Convert Gas Mixture From Mole% To Mass%Started by Guest_chemtoli_* , 12 Mar 2023 |
