Wfwman,
As the incoming air has passed on to the molecular sieve bed and leaves with a dew point of -70deg F.
While the air passed over the last layer/top layer of molecular sieve bed the bed is in equilibrium with -70 deg F. The air with -50 deg dewpoint without reducing pressure or increasing temperature will not be able to regenerate the bed.
All I can say a air with -50 deg F dew point cannot regenerate a bed which is in equilibrium with -70 degree Farenheit.
But if you blow the air with reduced pressure which I think you can do as by reducing the pressure by using a PRV(pressure reducing valve). Then the air with lesser pressure can desorb moisture from the bed. If I am not clear what I meant to say please let me know.
As you had raised doubts on molecular sieve not adsorbing moisture anymore kindly check its color whether it has turned brownish.
The regeneration of the molecular sieve would be possible with increase in temperature surely. Please check if you can install a heater. I could calculate and check what time would be required to desorb it. All I would require then would be adsorbent amount Air inlet temperature.
Edited by Supriyo Mukherjee, 13 May 2014 - 04:00 AM.
