Hi All,
I am reviewing the sizing of Methanol Vessel PSVs again. The PSVs will be sized for fire case.
In an effort to determine the temperature at relieving pressure using HYSYS for the mixture, I generated the envelope utility curve from the "stream attachment" and got a temperature of 136 C corresponding to the relief pressure of 948 KPa.
Another way is to force-input the relief pressure of 948 KPa and the vapor fraction as zero degree C and let HYSYS calculate the temperature. The calculated temp in this case is 143.6 C
Which one is the accurate way?
Sherif
