Sizing Fire Case Relief Valve Installed Below Liquid Level
11 replies to this topic
#1 processrock
processrock
  • 8 posts
Posted 14 April 2026 - 10:17 AM
Hi Engineers,
May I seek your guidance on the following?
I have a vertical vessel that is fully filled with water containing a trace amount of hydrocarbon. Due to a device located near the top dished head, the pressure relief valve (PRV) cannot be installed at the top and must instead be located on the side of the vessel, below the liquid level.
Per API 521, when a PRD is located below the liquid level of a vessel exposed to fire, the PRD should be capable of relieving a volume of fluid equivalent to the volume of vapor generated by the fire. It is also stated that two‑phase PRD sizing is generally not required for fire cases, except for unusually foamy materials or reactive chemicals.
In this case, how should the PRD be sized? If the relief device is installed on the vessel shell well below the liquid level, or on a liquid feed line, the relieving fluid under fire exposure would be liquid. If the vapor generation rate is used to drive the equivalent liquid flow rate, would this not result in an oversized PSV?
On the other hand, if only vapor generation is considered, there is a concern that the valve may be undersized.
I would appreciate your advice on the appropriate sizing approach for this scenario.
Thank you for your time and support.
  • 1,694 posts
Posted 14 April 2026 - 12:16 PM
Did you not answer your own question? I do not understand why this is not satisfactory to you. Have you calculated the fire case vapor generation rate for a vertical vessel containing water?
#3 processrock
processrock
  • 8 posts
Posted 14 April 2026 - 12:36 PM
My understanding is that if the inlet piping to the relief valve is submerged below the liquid level, the fluid entering the valve will not be vapor. Instead, any vapor generated will act as a driving force, pushing liquid through the relief path. As the liquid level drops and falls below the relief valve inlet nozzle, the relieving flow could transition from two‑phase to vapor‑only flow. If this is the case, why do we place emphasis on estimating the orifice size based on two‑phase or vapor flow scenarios? My assumption was that liquid flow driven by the expanding vapor would represent the worst‑case condition.
#4 Pilesar
  • 1,694 posts
Posted 14 April 2026 - 02:33 PM
Your situation is curious with a completely filled water pressure vessel with no vapor space at all. If the normal inlet or exit of the vessel is not blocked in, the fire case can consider those paths as a relief exit. Completely blocking in a filled water vessel with no vapor space is an additional relief scenario you must consider anyway due to thermal expansion. Why not just put the PRD near the bottom of the liquid? Is there no bottom nozzle?
  I think there must be more to this situation that you have revealed. If the vessel has no PRD now, then it must be in the design phase where you are determining where to install the vessel nozzle for a PRD. We do not know the size, pressure, function, etc of the vessel. It sounds like an interesting problem!
#5 processrock
processrock
  • 8 posts
Posted 14 April 2026 - 03:15 PM
Allow me to briefly provide the relevant information:
  • Equipment: Hydrocyclone (vertical)
  • Vessel diameter: 1.0 m
  • Tangent‑to‑tangent height: 1.4 m
  • Head: 2:1 ellipsoidal
  • Set pressure: 30 barg
That said, may I ask how locating the PRD near the bottom of the liquid would be beneficial? Also, please excuse my naïve question: according to API 521, when a PRD is located below the liquid level in a vessel exposed to fire, the PRD should be capable of relieving a volume of fluid equivalent to the volume of vapor generated by the fire. In this context, do we assume that the required liquid volumetric flow rate is equal to the volumetric rate of vapor generation due to the fire?
#6 latexman
  • 1,928 posts
Posted 14 April 2026 - 09:16 PM
Yes.
#7 breizh
  • 7,055 posts
Posted 15 April 2026 - 12:55 AM
A sketch please.
What is the link between the hydro cyclone and the vessel? why not installing the discharge of the hydro cyclone on the side of the tank to be able to install the PSV on the top head (vapor space)?
#8 processrock
processrock
  • 8 posts
Posted 15 April 2026 - 01:45 AM
Here you go.
The hydrocyclone contains two tubesheets that support the liners, and the PRD is typically located in the middle compartment because the outlet is prone to blockage due to the small hole sizes. As a result, we are uncertain whether, in this case, the PRD needs to be sized based on an equivalent liquid volumetric flow rate.
Edited by processrock, 15 April 2026 - 01:46 AM.
#9 breizh
  • 7,055 posts
Posted 15 April 2026 - 02:49 AM
Is your application similar to the one on the link attached?
Deoiling Hydrocyclones
#10 processrock
processrock
  • 8 posts
Posted 15 April 2026 - 03:51 AM
Hi Breizh,
Yes, that’s correct. However, the example shown in the link is in a horizontal orientation, where the highest point can be considered at the cylindrical body. In my case, the equipment is vertically oriented, so the highest point is near the blind flange or the reject oil outlet.
#11 breizh
  • 7,055 posts
Posted 15 April 2026 - 06:13 AM
So, what is the problem to add an additional nozzle for the PSV? between the PSV and the nozzle you can add a rupture disk to protect the PSV. Normally the PSV is only activated in case of fire,right?
PSV could be installed at the very top (existing nozzle) where the outlet could be installed on the side of head.
BTW why not increasing the disengagement head to have the oil outlet on the side and the PSV on the top, adding a few centimeters on the shell to install a nozzle should not be too expensive.
I cannot offer more.
#12 processrock
processrock
  • 8 posts
Posted 15 April 2026 - 08:26 AM
Hi Breizh,
The PRD is located at the inlet compartment because the liner’s oil outlet has a very small orifice and is prone to blockage. If a blockage were to occur and the PRD were installed at the oil outlet, it might not be able to adequately protect the inlet or the water outlet.
Thanks.
