If I have the characteristic curve of a pump at a given RPM and also the pressure drop vs velocity curve of the pipe, how do i find out the flow rate?
Centrifugal Pump's Flow Rate
Posted 10 June 2014 - 11:56 PM
Posted 11 June 2014 - 12:34 AM
HI,
Would you upload the curves? Usually the flowrate should be mentioned in the characteristics curves for a fixed RPM (a sample sketch is attached).
With the velocity and pipe size manually the approximate flowrate can be calculated also.
Posted 11 June 2014 - 12:42 AM
KirtiNemani ,
Consider reading this paper (about centrifugal pump)
The intersection between Pump curve and system curve will be the answer .
note : a lot of documents are available in this forum , use the search engine .
hope this helps
Posted 12 June 2014 - 07:48 AM
KirtiNemani:
As usual, Breizh has furnished you with some excellent advice and material. Unfortunately, the submitted article deals only with the Performance Curve (not characteristic curve) of a centrifugal pump and doesn't mention the development of a system curve for your application and how it can be superimposed on the Performance Curve.
If you don't know how to develop a system curve and how to use it, let us know and the forum members can help you on that subject - which is of great importance when dealing with centrifugal pumps.
Posted 12 June 2014 - 06:56 PM
KirtiNemani,
To reply to Art and to support our members , please consider this great resource (J chaurette) , in particular Chapter 4 for your specific requirement.
Enjoy the reading .
![]() Flow Through Normally No Flow LineStarted by Guest_iippure_* , 08 Apr 2025 |
