I thing what you are telling "SHAKE TEST" it is basically Doctor's Test
The chemistry of ‘doctor sweetening’ was described in detail by G. Wendt and S. Diggs in 1924. They showed that the lead oxide solution brought about oxidation of the mercaptans to the corresponding organic disulfides, which are comparatively odourless. Lead oxide (litharge) will dissolve in reasonably concentrated solutions of sodium or potassium hydroxide owing to formation of a soluble compound, sodium plumbite:
When this alkaline solution is agitated with petroleum, the two liquids do not dissolve in one another, but any mercaptan in the oil will unite with an equivalent amount of the lead (which then passes into the petroleum) to form what is called a lead mercaptide, soluble in the oil:
If the mixture is now treated with powdered sulfur, which has a high affinity for lead, a black suspension of lead sulfide forms, and conversion of the mercaptide into a so-called disulfide (which remains in the oil) is induced:
With no sulfur added, but in the presence of atmospheric oxygen, the same conversion occurs, but only slowly, and probably not completely:
It is evident that the process does not remove the sulfur from the oil but even may increase the sulphur content if too much powdered sulfur is added, and some of the lead may remain in the petroleum.
The described chemistry is also the basis of the doctor test for the sweetness or sourness of gasoline (i.e., the extent of sulfur contamination). A gasoline is described as doctor sweet if, after shaking with sodium plumbite solutions, the addition of powdered sulfur fails to produce a dark precipitate of lead sulfide
