Dear sir,
When to stop acid and caustic addition to SAC and SBA during regeneration? What criteria we need pls explain?
Thanks.
Posted 02 July 2014 - 05:59 AM
Dear sir,
Thanks.
Posted 02 July 2014 - 06:37 AM
If I understood your query well, I think during regeneration acid and caustic addition should be stopped when the H+ and OH- would be appeared in the outlets respectively...
Posted 02 July 2014 - 06:41 AM
On top of what Fallah explained , I would consider to contact the supplier of resins who should tell you the quantity of Acid or alkali to introduce per m3 of resin , this based on the strength of the chemicals .
The resource attached should give you clues about the monitoring of the process .
Breizh.
Edited by breizh, 02 July 2014 - 07:10 PM.
Posted 03 July 2014 - 02:31 AM
Thank you Fallah and Breizh.
Posted 12 July 2014 - 03:00 AM
Dear Fallah and Breizh
I checked our resin supplier brochure, it says that the regenerant flow should be 3-18 m3/hm2.I couldn't understand this unit please explain
me. thank you.
Posted 12 July 2014 - 03:11 AM
sarathkumar,
In fact, it is volumetric flux (not to be confused with volumetric flow rate) i.e. the rate of volumetric flow across a unit area of the total cross sectional area of the bed:
cubic meters/(1 hour*1 square meter)
Edited by fallah, 12 July 2014 - 03:13 AM.
Jt Based Hcdp Design V/s Mechanical Refrigeration Hcdp Unit.Started by Guest_BabRafiq1_* , 19 Apr 2024 |
Hydrocarbon Dew Point Control UnitStarted by Guest_BabRafiq1_* , 05 Apr 2024 |
Need Help In Calculating Ammonia Slip In Scr Unit.Started by Guest_Redbull010203_* , 11 Mar 2024 |
Oil Production And Desalting UnitStarted by Guest_Ali4269278331_* , 25 Feb 2024 |
Design Of A Psa Unit For Undergraduate Design ProjectStarted by Guest_LMorgan14_* , 04 May 2021 |
