I am currently reviewing WHCP vendor documents. Wellhead wing, master and SCSSV are hydraulic actuated valves operated by pneumatic pilot valves.
When a process shutdown signal is initiated, Wing valve, Master Valve and SCSSV valve (all hydraulic) are closed in a timely sequence. A pneumatic signal is sent to the pilot valves inside the panel, hence closing the valves on the hydraulic lines feeding the actuators.
My question is: When you close the valve, the line will still be pressurized hence the valves on the wellhead will not close. How can I make sure that pressure is already released for the valve to close?
Thank you
