I came across one equation called chen's correlation for pressure drop in packed bed. I could not understand what unit of measurements to be used because the equations seems to be semi emperical. Can any one help ?
Chen's Correlation Of Pressure Drop In Packed Bed
Started by Cyberspider789, Jul 11 2014 07:43 PM
Posted 11 July 2014 - 07:43 PM
Posted 14 March 2015 - 09:26 AM
Dear Cyberspider789,
Maybe Chen equation is only a part of your procedure. The Chen equation is for Fanning friction factor determination.
Where:
f = Fanning friction factor
k = absolute roughness (in)
D = diameter (in)
k/D = relative roughness (unitless)
Re = Reynold’s number
¿Do you have another equation?, please send me for review.
Napo.
Spray Dryer Nozzle Issue – Pressure Increase And Fines IncreaseStarted by Guest_Ella2365_* , 24 Mar 2026 |
Flow & Pressure Regulation For Compressible FluidsStarted by Guest_Abdessamed1961_* , 14 Dec 2025 |
