Purge Gas Rate Calculation
#1 Engineer87
Engineer87
  • Store Customers
  • 61 posts
Posted 28 July 2014 - 01:02 AM
Hi Guys,
I'm dealing with flare stacks for the first time.I read flame arrestor and the velocity seals are used alternatively somewhere.Is there any reference in API521 related to that?. Any formula calculating purge gas rate with no flame arrester?
#2 ankur2061
ankur2061
  • Forum Moderator
  • 2,484 posts
Posted 28 July 2014 - 06:24 AM
Engineer87,
Purge gas rates with seals (Buoyancy / Velocity) are based on the velocity of purge gas to limit oxygen concentrations below the seal to acceptable limits.
Once you know the velocity and the cross-sectional area of the seal / tip, you can calculate the volumetric flow rate of the purge gas.
For velocity range for flares with seals, refer Section 6.4.3.6.2 of API STD 521.
#3 Engineer87
Engineer87
  • Store Customers
  • 61 posts
Posted 28 July 2014 - 02:58 PM
Thanks Ankur for quick reply,
In AP1 521, its is sated that" Purge-reduction seals are not flame arrestors".Does presence of flame arrestor has any effect on the purge rate calculation?
#4 gegio1960
gegio1960
  • 518 posts
Posted 29 July 2014 - 12:23 AM
I've never seen flame arrestors in flare systems... so, I'd like to know where you've red of them.
thanks
#5 vanngoc
vanngoc
  • 8 posts
Posted 21 August 2014 - 10:19 PM
Engineer87.
You can use Husa equation for purge gas flowrate. Sorry thay I can not add the attachment here, but you can try on Google.
Edited by vanngoc, 22 August 2014 - 03:33 AM.
#6 breizh
  • 6,743 posts
Posted 22 August 2014 - 12:28 AM
http://www.capp.ca/g...px?DocId=137306
for information about Husa equation & gas purge flow rate  , take a look at the link above .
Edited by breizh, 22 August 2014 - 12:40 AM.
#7 ankur2061
ankur2061
  • Forum Moderator
  • 2,484 posts
Posted 22 August 2014 - 12:32 AM
"Husa" correlation should not be applied when velocity seals are provided.
