Choked Flow Of Air At Very Low Pressures?
#1 rbel038
rbel038
  • 7 posts
Posted 30 July 2014 - 06:02 PM
I am performing a calculation to size the flow rate through a small packed column to atmosphere (scrubber). The upstream flow rate is a maximum 500 Pascal (discharge pressure of purge fan) , according to the laws for choked flow of ideal gas, critical pressure ratio of air is around 0.528. If i do the quick calculation based on my upstream pressure I get 260 Pa as my downstream critical pressure.
Sure for such low pressure air cannot reach sonic velocity???
Appreciate your knowledge
#2 Bobby Strain
Posted 30 July 2014 - 06:25 PM
You must use absolute pressure.
#3 serra
serra
  • 311 posts
Posted 31 July 2014 - 12:41 AM
Bobby is correct, consider absolute pressure,
as far as I know there are no limits due to pressure for sonic velocity
(assuming you are estimating correctly the value),
the main problem with very low pressures in piping / vessels is that gas density
becomes low and  this can reduce maximum mass fllux (limited by sonic speed)
below the required values (at that point you have to increase pressure).
