Calculation Of Settling Velocity
#1 Ayok
Ayok
  • 10 posts
Posted 11 August 2014 - 08:13 PM
Does anyone know how to calculate settling time properly? I want to precipitate Fe(OH)3 from backwash water of my Iron Removal Filter. Actually i know a formula to calculate settling velocity from book for sedimentation, but i dont know about diameter of Fe(OH)3, so i'm stuck on it. I cannot do diameter measure test and i cant found diameter of Fe(OH)3 in book and internet. So, does anyone know how to calculate settling velocity with other way? Or should i do settling time test?
#2 Bobby Strain
Posted 11 August 2014 - 10:50 PM
I think you answered your own query.
#3 breizh
  • 6,751 posts
Posted 12 August 2014 - 12:15 AM
Ayok
You should perform Jar test ! this is the only way to get reliable data and this is the method used by Chemicals supplier looking after sedimentation and coagulation processes.
#4 Ayok
Ayok
  • 10 posts
Posted 12 August 2014 - 10:00 AM
Mr Breizh, i dont have proper equipment to do jar test since i'm only student and i dont have access lab. Is there any simple way to do jar test sir?
Thanks Mr Breizh and Mr Bobby. I really apprecite your help
#5 kan_gou_lai
kan_gou_lai
Posted 12 August 2014 - 11:25 PM
1 particle Fe(OH)3 in dispersed form, also called colloid, is of dimension around 0.1 um will take forever to settle. in water treatment, it will be a group of thoses colloids Fe(OH)3 and other suspended solids (created after flocculation which make the particules biggers) will settle at less than 2 m/s.
Very good design of flocculation & settling tank (without polymer aid) can function at 6 - 8 m/h
#6 breizh
  • 6,751 posts
Posted 13 August 2014 - 12:54 AM
Ayok ,
Consider reading this general paper :http://www.rpi.edu/d.../sedsettle.html
Probably a good resource could be any Books dealing with Waste water treatment .
