Gasoline Vapor Cracking
Started by 49lone82, Aug 13 2014 03:30 PM
Posted 13 August 2014 - 03:30 PM
I'm working on a vehicle running on vapor and would like go to go one step farther by cracking the vapor What temperature do I have to get the vapor to to crack it?
Posted 29 August 2014 - 07:55 PM
Seems like you would like to break the fuel molecule apart into smaller molecules, but without yet combusting or burning the fuel? This may take temperatures between very roughly 600-1200dC, and depends on fuel composition, pressure, and whether any catalysts are present to say help the cracking occur at a lower temperature. This process may be prone to fouling with solid coke due to the high temperature.
Edited by Dazzler, 29 August 2014 - 07:56 PM.
Ammonia Line Vapor GenerationStarted by Guest_simadri_* , 07 Apr 2025 |
![]() N2 Blanketing To Gasoline Tanks With IfrStarted by Guest_NICOLAST_* , 20 Dec 2024 |
Minimum Vapor Disengagement Area For A Kettle BoilerStarted by Guest_Engib33r_* , 17 Oct 2024 |
![]() Gasoline Storage TankStarted by Guest_Lucianaa_* , 29 Aug 2024 |
How To Right Size A Vapor Recovery Unit (Vru)?Started by Guest_MethanolPlant_* , 29 Apr 2024 |
