Choosing Fraction Of Components (Hysys)
hysys simulation
#1 Leovm
Leovm
  • 3 posts
Posted 28 August 2014 - 04:47 PM
I have been trying to build a simulation on Aspen HYSYS but I am facing a small problem with stream's compositon. Even after I have chosen each component fraction in a stream, my simulation still does not calculate anything. It's quite simple but I got stuck! The odd is when I build a simulation containing just one component it works fine.
Any ideas will be helpful!
#2 Bobby Strain
Posted 28 August 2014 - 08:23 PM
Look carefully at your input to make sure it is complete. Flow, temperature, pressure as well as composition.
#3 Leovm
Leovm
  • 3 posts
Posted 28 August 2014 - 09:30 PM
To be especific, I am facing this problem at a separator.
Inlet:
0.5 ammonia and 0.5 water (mass)
Pressure: 3000 kPa
Temperature: 150 ºC
Mass flow: 86060 kg/h
Outlet:
-Vapor
100% ammonia
Pressure: 3000 kPa
Temperature: 150 ºC
Mass flow: 24084 kg/h
-Liquid
0.30569 ammonia (mass)
Pressure: 3000 kPa
Temperature: 150 ºC
Mass flow: 61975 kg/h
The separator is always "not solved". Hoping to hear from somebody, thanks in advance
#4 breizh
  • 6,720 posts
Posted 28 August 2014 - 10:11 PM
Leovm
Consider the attached document to support your work ,  from Internet .http://www2.questcon...mo/thermot.html
You  should get similar results !
hope this helps
Edited by breizh, 29 August 2014 - 06:45 AM.
#5 himant
himant
  • 53 posts
Posted 03 September 2014 - 11:02 PM
that's a very unusual error...
make sure that
1. you do not define any of the separator outlet properties (either liquid or vapor).
2. simulation is not put on hold by clicking on the above green button.
I hope it will work
Himant
