I'm currently working on to determine the most effective/economical insulation thickness for a external floating roof storage tank. The requirement of insulation is to limit heat leak. However we don't have a limiting condition or heat limit to refer to. Any rule of thumb or standard acceptable heat limit that we can use? Need it to verify whether the thickness that we select is sufficient or suitable.
Appreciate your thoughts and thank you in advance!
Samantha
