Flare System In Gas Processing Plant
#1 Max3008
Max3008
  • 13 posts
Posted 05 September 2014 - 08:31 AM
Dear all,
As far as I know, a flare system usually includes flashback seal drum and flashback prevention section as in picture below:
However, the flare system in some gas processing plants I know does not include any flashback seal drum or flashback prevention section. It just includes K.O Drum and there is a "annular slot" in the flare stack. I wonder if it is safe and the "annular slot" could play the role as a flashback prevention section?
Thanks in advance,
Hoang
Edited by Hoang Nguyen, 05 September 2014 - 08:33 AM.
#2 fallah
  • 5,026 posts
Posted 05 September 2014 - 08:51 AM
Nowadays there are other facilities than seal drum for flashback prevention through the flare tip such as velocity seal along with a continuous purge gas system which can create a situation to do the job safely. Continuous purge gas system create a reliable positive pressure that its interruption may even lead to plant shut down...
Edited by fallah, 07 September 2014 - 12:52 AM.
