Dear all,
What's the typical distance between corrosion inhibitor injection point and corrosion coupon/probe? is there a guideline or standard.
Best regards.
Posted 12 September 2014 - 03:39 AM
Dear all,
Best regards.
Posted 12 September 2014 - 04:33 AM
The injection point is located downstream closed to corrosion coupon/probe because of injection dosage can refer to coupon/probe result.
However how closed is the distance?
The typical distance as fas as i know is around 2 ft.
The guideline is come from each COMPANY standard that may differ from one to another.
Burners Flame Monitoring System RequirementStarted by Guest_Movers_* , 23 Nov 2023 |
Monitoring Of Level Control In Steam BoilersStarted by Guest_Movers_* , 14 Sep 2022 |
Heat Exchanger MonitoringStarted by Guest_CHEMSTRONG_* , 13 Aug 2022 |
Corrosion In RefineriesStarted by Guest_CHEMSTRONG_* , 19 Jun 2022 |
Refinery Corrosion InhibitorsStarted by Guest_CHEMSTRONG_* , 03 Apr 2022 |
