Centrifugal Pump Datasheet
pump data sheet
#1 SweAks
SweAks
  • 3 posts
Posted 13 October 2014 - 03:17 PM
I am working on filling a centrifugal pump data sheet for purchase. I am a process engineer. The pump data sheet require to fill all the minor details; this is the first time i am filling pump data sheet, and i am not familiar with lot of these terminology (ex; Casing Mounting type, Casing Split, Impeller Mounted, Rotation, Shaft, Couplings, Mechanical Seal, Packing Data..etc). I can copy from a go by, but i also want to know what these terminology means. I assume the industry uses more or less similar centrifugal data sheets in all the companies. Is there any place, where i can find an explanation of these terms. Thanks for your help.
  • 6,789 posts
Posted 13 October 2014 - 05:37 PM
http://centrifugal-p...rg/sitemap.html
This link may help you.
#3 nguyen_trung_dung
nguyen_trung_dung
  • 9 posts
Posted 14 October 2014 - 09:36 AM
Hi SweAks
I think it's better to get Mechanical Engineer involved, otherwise you are recommeded to work directly with vendor.
Dung
#4 SweAks
SweAks
  • 3 posts
Posted 15 October 2014 - 03:26 PM
Thank you breigh and nguyen_trung_dung!
#5 farid.k
farid.k
  • 384 posts
Posted 16 October 2014 - 04:12 AM
As process engineer, for me it is not your role to fill that. Your role normally is to specify the differential pressure, npsha, suction and discharge pressure. That should be specify by mechanical. It is good to know but sometimes it can create headache.
