Mesh Screen Size
#1 farid.k
farid.k
  • 384 posts
Posted 12 November 2014 - 04:17 AM
hye,
how to specify mesh size for the strainer? the fluid is steam, strainer is upstream of control valve. i don't really know why do we need to have strainer at upstream of control (existing system) valve and how to specify it.
your sharing is highly appreciated.
  • 6,890 posts
Posted 12 November 2014 - 08:11 AM
Farid,
This is to prevent rust to block the cage of the valve . Probably Spirax sarco website should provide the answer or Check with your E&I engineer or valve manufacturer.
http://www.filter.ee...s/230-21742.pdf
Hope this helps
Edited by breizh, 12 November 2014 - 06:18 PM.
#3 samayaraj
samayaraj
  • 239 posts
Posted 12 November 2014 - 09:28 AM
Hi farid,
For strainers, generally it should have the mesh opening area which is more than 4 times the cross section of pipe. This is generally used to avoid frequent chocking of strainer. In few cases, it is 2 times the CSA of pipe.
From this, you can choose mesh size. Here the avg dirt particles should be greater than the mesh opening size.
#Samayaraj
