Pneumatic Pump (Diaphragm Pump) Discharge Pressure
pneumatic pump pump diaphragm pump pressure discharge pressure
#1 ashokg9
ashokg9
  • 11 posts
Posted 20 November 2014 - 02:08 AM
 In operation of diaphragm pumps, pneumatic air supply is used at around 3.5 Kg/cm2  - 6 Kg/cm2. I am confused, how can this pump develop discharge pressure more (say 10 kg/cm2)  than the pneumatic supply pressure which is used for its working.
Thanks,
Ashok
  • 6,797 posts
Posted 20 November 2014 - 06:50 AM
Ashok ,
Take a look at the pump curve .
For reference a brochure from Yamada .
and a link with pump curve
http://www.all-flo.c...nce-curves.html
Hope this helps
Edited by breizh, 21 November 2014 - 12:45 AM.
#3 shan
shan
  • 692 posts
Posted 20 November 2014 - 07:59 AM
The principle is the act/react force area difference.  If the air side area = 1cm2,
3.5 kg/cm2 * 1cm = 10 kg/cm2 * x
x = 0.35 cm2
Therefore, you will have 10 kg/cm2 pressure if your discharge side area is 0.35 time of air side area.
#4 farid.k
farid.k
  • 384 posts
Posted 21 November 2014 - 02:57 AM
I love the question. I think, it same with hydraulic principle. Just a small amount force can live up a big car.
