Hello everybody,
I would like to have your insights about an issue I'm currently dealing with.
Situation: Imagine a vessel which function is to collect liquids (production fluids, chemicals, water, etc, none of them above 70 deg C) and hold them up to pump them to the drain header. One line is connecting this vessel to a header which is routed to flare, providing this safeguarding to the vessel in case of overpressure (also considering the fact that, under certain scenarios, the vessel will handle two-phase fluids). this header also collects a gas stream that is routed to flare. A simplified scheme is attached.
Vessel.jpg 13.74KB
3 downloads
In case of a "catastrophic scenario", this gas stream could reach really high pressures (up to 340 barg) so a restriction orifice is provided to assure a manageable pressure for the flare header (around 0.5 barg). Obviously, such a high depressurization will lead to really low temperatures (since the gas stream is HC, mostly methane) but all the chosen materials can cope with that.
The problem: During a HAZOP study, one of the concerns was that, during normal operation, the line connecting the vessel with the flare header will pressurize the system, including the piping connected to the gas stream (and the RO) with gas that may contain water (from production fluids or even water in equilibrium within the vessel (please note that holdup times are high enough to think and equilibrium can be reached). Then, in case of a catastrophic event, the depressurization will cause a temperature drop that will freeze the water vapour leading this to a potential blockage of the line..
My opinion: From the process engineering point of view, I think this will not happen. The fluid velocity during the depressurization (that most likely will be at least mach 1) will push all the gas present in the line away (and all the water vapour will go away. However, I was told that this was not an acceptable assumption for a HAZOP. Also, in the case that the vessel holds water in equilibrium, even the flare backpressure will prevent the water vapour (with a Vapour pressure of around 0.09 bara, as its temperature is 45 deg C) to pressurize the system.
What is your opinion regarding this?. Can you suggest more arguments to support my position?. Do you see a wrong assumption from my side?.
Thanks in advance for your help!.
