How do I obtain a taylor expansion and thus the approximation for a function f(x, y)? Should I use the partial derivative wrt to x or the one wrt to y?
Thanks to anyone who can help me with this..
Taylor Series Expansion
Started by ss3, Apr 20 2006 04:28 PM
Posted 20 April 2006 - 04:28 PM
Posted 21 April 2006 - 10:31 AM
You can do a Taylor expansion for one variable around one value, e.g. x0. So in that case y is assumed constant and you take the partial derivatives with respect to x. Alternatively, you can expand around y0 with respect to y. I suppose if you add the two series, you get a function 2*f(x,y) - but I am not a mathemagician. Note that it will be an approximation, and it gets worse if you try to do it in two dimensions.
![]() Fire Case Gas Expansion (Gas Filled & No Liquid)Started by Guest_moosa.akbar_* , 27 Aug 2024 |
Using Similar Check Valve In SeriesStarted by Guest_vsnlbom_* , 22 Dec 2023 |
![]() Aspen Edr - S&t: Process Side Series / Cw Side ParallelStarted by Guest_mitch22_* , 06 Feb 2023 |
![]() Butane Thermal Expansion By Sun Radiation In PipeStarted by Guest_fedi.abdeljawed_* , 10 Jan 2023 |
Switching From Parallel Mode Into Series ModeStarted by Guest_ahmed abd elmonem_* , 17 Jan 2023 |
