Hello All,
For relief header sizing and flare system design, does relief from manual blow down have any appreciable impact considering the fact that ideally manual blow down is not instantaneous.
I'd appreciate your expert opinion on this.
Posted 27 November 2014 - 05:26 AM
Hello All,
Posted 27 November 2014 - 08:04 PM
Hi David
Normally your blowndown system is designed for blowdown from PSHH or design pressure and the flare system is according to this basis as well. Does your manual blowdown means blowing at operating condition? if yes, the flare system can handle with your scenario.
Posted 28 November 2014 - 07:08 AM
Thanks @AlertO for your swift response.
Currently I'm working on a gas handling facility project where the 3rd party consultant for the flare system is requesting for the maximum relief loads and other gas properties from the manual blow down valves for the flare header sizing. What if you are to blow down manually after an emergency shut down, does this still contribute to the determination of the flare system capacity.
Posted 28 November 2014 - 09:58 AM
Blow down in order to depressurizing either to be done manually or automatically following to an emergency shut down has to be contributed to the determination of the flare network capacity...
Posted 30 November 2014 - 08:45 PM
Dear david
The blowdown after emergency shutdown is always one of the design case for flare system capacity. After ESD you have to assume that your system is under the servere condition and the initial process pressure shall be at PSHH, design pressure or settling pressure (for compressor). This will give you the maximum flow for determining the capacity of the flare capacity.
However, the flare capacity maybe sized based other scenario i.e. PSV relieves due to fire, electrical failure etc when the blowdown case isnot the governing case.
Edited by AlertO, 30 November 2014 - 08:45 PM.
Posted 01 December 2014 - 04:46 AM
Thanks Fallah and AlertO.
Impact Of Ambient Temperature And Solar Radiation To A Gas StreamStarted by Guest_Jon K_* , 06 Apr 2023 |
Manual Creating New Component And Setting Properties In HysysStarted by Guest_Platonicus_* , 15 Mar 2023 |
Centrifugal Compressor Off-Design Inlet Conditions ImpactStarted by Guest_Said Salim_* , 10 Aug 2022 |
Manual Depressurisation - How To Determine Restriction Orifice SizeStarted by Guest_FUNMILAYO_* , 14 Oct 2020 |
Manual DepressurizationStarted by Guest_Danish John Paul_* , 04 Jun 2021 |
