Solid Liquid Separation
filtration
#1 sateeshkumar830
sateeshkumar830
  • 40 posts
Posted 17 December 2014 - 05:41 AM
Sir,
    My name is Satish kumar working for a pharma industry. My query is how to select a filtration equipment for solid liquid separation(filtration). on what parameters does the filtration depends ?? we have filtration equipments like centrifuge, nutsche filter, Agitated nutsche filter, pressure nutsche filter and Robo filters. Can u please explain me how can we select filtration equipments for different slurries, and on which parameters does the filtration depends ??
#2 MTumack
MTumack
  • 57 posts
Posted 17 December 2014 - 01:44 PM
Its a pretty involved process...
I would phone a filter supplier and talk to an application engineer with the Micron sizes of the solid particles you need to remove. Also depends on other properties of the fluids / filters.
What kind of viscosity, what kind of flow rate, what kind of maintenance schedules, what kind of maintenance operations you would like to use (Replacement, filter change out, filter cleaning), what percentage of your slurry is a solid and what percentage is a liquid, is the solid abrasive or non-abrasive (IE Icing sugar (nonabbrasive) vs Sand (Very abrasive), is there any corrosive potential chemically (H2S, etc), is there any flammable potential, are the solid subject to break, are the solids hygroscopic....
Answer these questions and a host more about your design service and requirements and phone up a Filter Supplier, hear what the expert on solid/liquid filtration has to say.
Asking how to specify a solid/liquid seperation unit is kind of like asking "how to solve an equation" without providing an equation.
#3 breizh
  • 6,817 posts
Posted 17 December 2014 - 07:03 PM
This resource may help you : http://www.filtratio.../simulation.htm
Probably good to take look at Perry's chemical engineering handbook .
Good luck .
#4 breizh
  • 6,817 posts
Posted 19 December 2014 - 07:41 PM
http://www.bhs-filtr...om/technical/#1
Sateeshkumar830 and others,
Consider the documents attached , very good information for those like me dealing with API . To keep in your tools box.
Good luck.
Edited by breizh, 19 December 2014 - 07:43 PM.
