Blowoff Manway
#1 sathyasamyu
sathyasamyu
Posted 24 December 2014 - 03:18 AM
Are blowoff manway needed for bitumen tanks(atmospheric tanks- vertical cylindrical)?
#2 ankur2061
ankur2061
  • Forum Moderator
  • 2,484 posts
Posted 24 December 2014 - 03:55 AM
sathyasamu,
That depends on whether emergency venting due to external fire is a credible scenario for your bitumen tank. If yes, an emergency venting device is required which can also be a blow-off hatch which is a non-reclosing type overpressure protection device similar to a rupture disk.
#3 fallah
  • 5,019 posts
Posted 24 December 2014 - 04:15 AM
sathyasamyu,
If the tank isn't equipped with a frangible roof and there are one or more credible over pressure scenarios whose relief loads are (much) higher than that of normal venting (fire case, gas blow by case, PCV failure to be in wide open position,...); then the tank required to be equipped with a blow off or emergency man way...
