I am the newbie for this so I want to sim the Adsoption column.
Feed consist of Ethylene Water & Ethanol so I want to use the zeolite to adsorb water and ethanol but I dont know how to start this.
Thx a lot for every comments
Posted 30 December 2014 - 01:35 PM
Posted 01 January 2015 - 01:38 AM
tyurata,
is it a theoretical problem or a real situation?
in the second case, you should know that no simulation is needed for this kind of system.
in both cases, you should start to collect the process data:
- flow
- pressure
- temperature
- composition
- target concentration of water at outlet of the adsorption column
just to start...
good luck
Modeling Liquid-Liquid Membranes In Aspen PlusStarted by Guest_bodinjas_* , 18 Mar 2025 |
Batch Adsorption: H/d Ratio For Vessel SizingStarted by Guest_Victor_process_Engineer_* , 28 Feb 2025 |
