Calculating Critical State Compressibility Factor
compressibility factor
#1 ezralh
ezralh
  • 32 posts
Posted 22 January 2015 - 02:56 AM
How to determine the compressibility factor, Z for hydrogen at 300 K, 24 barg? Since it is at critical state (Tc= 33.2 K and Pc = 13.1 bar), can I assume Z = Zc = 0.305? I tried Peng/Robinson and the iterations converge to 1.0073
#2 serra
serra
  • 311 posts
Posted 22 January 2015 - 04:11 AM
you may use tabulated values or a EOS,
with Peng Robinson for hydrogen (due to its properties) for accurate values you may prefer a specific alpha function (for example a "extended" Peng Robinson),
the value of compressibility for hydrogen calculated by a Extended Peng Robinson (Prode) at 300 K 20 bar.a is 1.014 which is not too different from the value calculated by you,
#3 ezralh
ezralh
  • 32 posts
Posted 22 January 2015 - 04:51 AM
Dear Serra,
Does that means I can use the value from Peng- Robinson, even though it is at critical state? 0.30 and 1.0 is very very significance
#4 serra
serra
  • 311 posts
Posted 22 January 2015 - 05:47 AM
the value of critical compressibility (for hydrogen I have values a bit different from yours) is calculated from density at critical conditions (i.e. p = pc, t = tc for hydrogen),
at 300 K 20 Bar.a you are far from critical condition and as you see at these conditions even ideal gas law (i.e. Z = 1.0 instead of Z = 1.014) gives a reasonable estimate.
