Api 610 Material Selection Basis
#1 colt16
colt16
  • 118 posts
Posted 03 February 2015 - 08:17 PM
Dear all,
In API 610 Material Selection guideline, it is described that for Naphtha and temperature under 230 degC, Class S-1 material will be used.
This means that for Naphtha, cast Iron impeller material may be used. Our client specified Class S-6 which is an overspecification based on API 610.
Does anyone have experience using Class S-1 material at this moment with any experience to share about material selection? Are there any issues with the use of Class S-1 material for naphtha service?
#2 Bobby Strain
Posted 03 February 2015 - 08:53 PM
If your client is paying the bill, why not supply the material he has requested?
#3 colt16
colt16
  • 118 posts
Posted 03 February 2015 - 09:25 PM
Because there is responsibility on our part to highlight overspecifications.
Also working with a budget, the savings can be transferred to other areas of the project.
#4 Zauberberg
Zauberberg
  • 2,728 posts
Posted 04 February 2015 - 07:48 AM
API 610 also states that S-3 or S-6 materials should be used if there is a presence of process water in Naphtha stream (reflux stream, product draw-off etc.), for temperatures below 175 degC. The class S-1 assumes virtually clean Naphtha stream, which may or may not be the case in your application.
#5 colt16
colt16
  • 118 posts
Posted 04 February 2015 - 08:25 PM
I see your point. Thank you very much for your reply.
Naphtha we are working with is bought from the spot market (not produced).
Thus if S-3 is sufficient for these services, perhaps S-6 is not required.
