Lean Amine Temperature Lower Than Inlet Gas Temperature In Absorber On
12 replies to this topic
#1 Dmitry
Dmitry
  • 180 posts
Posted 18 February 2015 - 12:26 AM
We have Amine tratment unit to remove CO2 and H2S from natural gas with 5,89 % mole fr. of CO2 and 0,15 % mole of H2S in ilet gas. We are using 50% weight of MDEA in lean amine solution.
Components      Content
                         wt %   mol %
H2S                 0,293   0,158
Helium              0,001   0,006
Hydrogen          0,007   0,066
CO2                 14,107 5,893
Nitrogen            0,371   0,243
Methane            79,238 90,803
Ethane               3,394   2,075
Propane             0,882   0,368
Iso-butane         0,262   0,083
Н -butane          0,214   0,068
Iso-pentane        0,134   0,034
Н- pentane        0,073   0,019
psC6                0,136   0,030
psC7                0,339   0,065
psC8                0,364   0,063
psC9                0,138   0,021
С10+               0,048   0,007
Total:               100,00 100,00
Standard density, kg/m3        0,766
Molar weight, g/mole 18,38
Relative density (against air) 0,636
Pressure in Absorber is 6 MPag.
Gas flow rate is 30 MMSCFD.
Lean amine flow rate is 50 m3/hr
Current lean amine temperature is +40 deg. C.
Inlet gas temperature is + 32 deg. C.
I know that lean amine temperature should be always higher at 5-10 deg. C. than gas temperature to avoid condensation of hydrocarbon in absorber, so it could start foaming, amine loses and so on... However we measured real HC dew point og gas upstream absorber and recieved it +15 deg. C.
My question is could we reduce gas temperatur from +40 to + 25 deg.C? We will keep 10 deg. C above HC dew point so no liquid should be in absorber.
Many thanks,
Dmitry
Edited by Dmitry, 18 February 2015 - 12:37 AM.
#2 Zauberberg
Zauberberg
  • 2,728 posts
Posted 18 February 2015 - 01:58 AM
I'd suggest a good reading on the subject, pages 1-5 from the document: http://www.bre.com/p...ulesofthumb.pdf
If the absorber works fine with the current setup, don't try to fix it.
#3 Dmitry
Dmitry
  • 180 posts
Posted 18 February 2015 - 02:57 AM
Thanks, we want to make a study with reducing gas temparature and removing of H2S and CO2. Now it's work fine but we want to increased gas flow from 30 MMSCFD to 60 MMSCFD, while design is 40 MMSCFD. So what do you think?
Dmitry
#4 Zauberberg
Zauberberg
  • 2,728 posts
Posted 18 February 2015 - 03:11 AM
I think that much more information would have to be provided in order to assess this subject. Everything is possible - the true question is at what price it comes.
We don't know the design case for your absorber, neither the design conditions for amine solution. If the absorber diameter is set based on the gas flow, I'm afraid there is no way you can put 100% more gas through it. If there is a good margin to increase vapor/gas throughput, then you would have to see if amine circulation rate or concentration can be increased, and if the entire regeneration section can handle the new set of conditions. I seriously doubt this can be achieved.
There is a whole array of unit benchmarking activities that need to be undertaken before one can give a more precise answer.
#5 PingPong
PingPong
  • 1,474 posts
Posted 18 February 2015 - 05:42 AM
What really matters is not the hydrocarbon dewpoint of the gas upstream the absorber, but the hydrocarbon dewpoint of the sweet gas (free of CO2 and H2S) leaving the absorber at the top.
The lean amine has to be warmer than that sweet gas hydrocarbon dew dewpoint.
In fact: at any point in the absorber the amine has to be warmer than the hydrocarbon dewpoint of the gas at that same point.
Edited by PingPong, 18 February 2015 - 05:45 AM.
#6 RockDock
RockDock
  • 257 posts
Posted 18 February 2015 - 01:00 PM
How do you know your hydrocarbon dew point? Is it modeled or sampled? Do you have any BTEX?
#7 shan
shan
  • 692 posts
Posted 18 February 2015 - 02:17 PM
It seems to me that your lean amine temperature (+40 deg C) is higher than your inlet gas temperature (+ 32 deg C).  Isn't it?
#8 Bobby Strain
Posted 18 February 2015 - 06:55 PM
If it's working, keep fixing it until it no longer works!
#9 Dmitry
Dmitry
  • 180 posts
Posted 19 February 2015 - 12:17 AM
We have HC dew point measurement device, which I connected to the gas process line upstream Amine unit
Dmitry
#10 Dmitry
Dmitry
  • 180 posts
Posted 19 February 2015 - 12:19 AM
Yes, this is normal operating range of temperatures. We always keep 5...8 deg. C. difference.
Dmitry
#11 Dmitry
Dmitry
  • 180 posts
Posted 19 February 2015 - 12:24 AM
Thanks, but I explained that we want to increase gas production from 30 MMSCFD to 60 MMSCFD, while design is 40 MMSCFD.  We already has 50 MMSCFD  with well CO2/H2S recovery, after we optimized lean amine flow and temperature.
So adjusting amine flow rate, gas/amine temperature we try to optimize CO2/H2S recovery.
Only one way is to make a study with reducing gas temparature and removing of H2S and CO2 and next parameters.
Dmitry
#12 RockDock
RockDock
  • 257 posts
Posted 19 February 2015 - 09:40 AM
A HC dew point of 15 C seems very low to me with a gas like yours.I would expect it to be around 25 C. I recommend taking a sample of the gas to send to the lab to be sure.
What is your sweet gas composition right now?
Decreasing the temperature will decrease the CO2 being reacted with the MDEA, increasing your CO2 in the sweet gas. Do you have room for the CO2 to increase?
#13 Bobby Strain
Posted 19 February 2015 - 03:23 PM
Once you have achieved the maximum rate by adjusting parameters, add a bit of MEA to your amine solution. Or, call BASF and pay them for activator.
