Hi All,
I am looking to build or modifying an existing scrubber to accommodate the parameters below (as much efficiency as possible)
300 mm ID inlet pipe
Linear velocity = 2.4 m/s therefore volumetric flow = 0.679 m3/s (254 m3/h)
NO 1000 ppm
NO2 2000 ppm
SO2 530 ppm
Cl2 15000 ppm (1.5%) (possibly ClO)
Temp = 300C
Pressure = I just assumed atmospheric as I could not measure it.
Scrubbing solution = 15% NaOH
Scrubbing volumetric flow rate = 4200 L/h
Pressure drop is not an issue as the stack heigh is only 5 m and the blower speed is variable to counter act pressure drop from the packing.
I have a small scrubber from a fume cabinet that has a cavity 450 mm x 450 mm. I proposed a bed height of 350 mm packed with 1 inch pall rings.
Does anyone have any advice of resources to confirm these calculation.
Cheers
