I would like to get some recommendation for brands of control valve people have seen success with when utilized on inlet two phase or three phase separator liquid dumps.
The current brand we use is the Flowserv Mark 1:
http://www.flowserve...rol-Valve,en_US
The following are normal operating parameter:
Inlet separator pressure :300 psi
Temperature: 60 F
Control valve outlet : 70 psi
Flow Rate: 400 BPD
Valve Size: 2 in
Solids concentration: 100 mg/L (iron sulfide)
Solid average particle size: 100 micron
The problem we are seeing is that the valve has a tendency to leak after 4-5 month in service. Other brands of valves have shown a tendency to get hung up due to solid build up.
