Tubulair Heat Exchanger
16 replies to this topic
#1 process16
process16
  • 46 posts
Posted 17 March 2015 - 10:00 AM
hello
i want  to ask you some questions about tubulair heat exchanger ( 2 f fuilds with counter courant)
whene we say Q= mCp( T2 - T1 )
what Cp we should take Cp related with T1 or T2?
2/ whats the simple meaning of DTLM?
3/whats the calorique temperature?
4/ what is the proper transfer coefficientUp )??
thank you
#2 gegio1960
gegio1960
  • 518 posts
Posted 17 March 2015 - 10:38 AM
why not a good heat transfer textbook? like the classical kern, or perry.
after that reading, you can make the residual questions in the student section of this site.
good luck!
Edited by gegio1960, 17 March 2015 - 11:34 PM.
#3 process16
process16
  • 46 posts
Posted 17 March 2015 - 04:06 PM
thank you
i have  an urgently calculation to do , i made a quick view and i guess if someone really  understood heat transfer  , he can give  me  good  answers
thanks again!!
#4 breizh
  • 6,942 posts
Posted 17 March 2015 - 06:50 PM
tarek12
Try the search feature in this forum , a lot of materials already posted there.
Note : any heat transfer text book or Google will answer your query.
Edited by breizh, 18 March 2015 - 01:42 AM.
#5 gegio1960
gegio1960
  • 518 posts
Posted 18 March 2015 - 12:00 AM
ok, tarek... trying to help you a little bit more while you follow breizh (and mine) advice....
1) you can take Cp at the average temperature between T1 and T2 (each side)
2) you'll easily find the formula for LMTD on the advised sources
3) for the caloric temp you can read this recent thread
http://www.cheresour...eat-exchangers/
4) in order to obtain a sound U (overall heat transfer coefficient) you have to consider the nature of your two streams and and a published table of Us... you could start from this point
http://www.cheresour...heat-exchangers
Good luck... and let us know about your progresses, doubts and results ;-)
#6 process16
process16
  • 46 posts
Posted 19 March 2015 - 02:40 AM
thank you brotheres;  i will check its, and tell u about my progress
#7 IGC
IGC
  • 54 posts
Posted 20 March 2015 - 10:47 AM
I'm assuming there is no phase change in this heat exchanger?
#8 process16
process16
  • 46 posts
Posted 20 March 2015 - 04:38 PM
no there is isnt ,  we have  hot oil used to heat crude oil
#9 gegio1960
gegio1960
  • 518 posts
Posted 20 March 2015 - 11:29 PM
...an interesting piece of information that could help in the estimate of U.
site: refinery or field? hot oil normally not used to heat crude oil in a refinery....
is it a new STHE or an existing one to be verified?
which kind of crude oil? light/heavy? raw/desalted/flashed?...
what about the temperatures and the flowrates of the two fluids?
Edited by gegio1960, 20 March 2015 - 11:57 PM.
#10 Padmakar Katre
Padmakar Katre
  • 992 posts
Posted 21 March 2015 - 12:30 PM
What is your exact intent, you want to just estimate the heat transfer area required to meet the desired duty or have to do detailed calculations? If former is correct, you estimate LMTD, pick the typical U value for this service and estimate area. If you need the detailed calculations then you should get hold of Heat transfer Handbook by Kern or any other Author. Good luck.
#11 breizh
  • 6,942 posts
Posted 22 March 2015 - 02:16 AM
http://www.hcheattra....com/tools.html
To support your work but you need first to understand the basics about Heat transfer.
Good luck.
#12 process16
process16
  • 46 posts
Posted 01 April 2015 - 04:29 AM
well i read some files  about heat transfer and  how  to do an exacte calculate
my object is  to do a  calculation to determinate the flow massique of the hot  liquide but  the prob  is  ; the out let temperrature of hote liquide  is  unknown too
here we   are   given :
we  want to heat up the  crude  oil with a specifique gravity of 0.762 from 34°c to 60°C and  i know  also  the flow massique of  the crude oil
the liquide used for heat is an oil
we have just its  density,  the inlet temperature
Edited by tarek12, 01 April 2015 - 07:55 AM.
#13 process16
process16
  • 46 posts
Posted 01 April 2015 - 09:18 AM
Good luck.
sorry but  iwhene we download files  we need a password!!!
#14 breizh
  • 6,942 posts
Posted 01 April 2015 - 05:57 PM
tarek 12
No password required !
#15 gegio1960
gegio1960
  • 518 posts
Posted 02 April 2015 - 03:10 AM
mmm... it seems a puzzle ;-)
from an "external post", we can also know that the HE is an existing one and the flow of crude oil is 90 m3/h.
maybe in the next posts we will acknowledge the inlet temperature of the hot fluid.,,,
#16 process16
process16
  • 46 posts
Posted 04 April 2015 - 04:24 AM
tarek 12
yes yes  i got  it than you!!!
#17 process16
process16
  • 46 posts
Posted 04 April 2015 - 04:27 AM
well ,  we  will fix  the flow  massique of teh  hot oil, then  we  will apply Q =mCp (T2-T1)
Q1= Q2 we  will get the out let temperature of the  hot  oil
but in this  case wich Cp of hot oil we  should  take? maybe Cp of inlet temperatur??
