We have wet gas flow meter which is not working.
Can we calculate flow from choke valve upstream and downstream pressure and temperature readings in 8" pipe dia....
Posted 18 March 2015 - 01:39 AM
Posted 18 March 2015 - 03:59 AM
it would be difficult without a proper calibration curve,
if you know only CV (or equivalent orifice area) you may get some idea but accuracy is questionable...
Edited by serra, 18 March 2015 - 04:06 AM.
![]() Wet Scrubber Design For Low Flow Rate Of GasStarted by Guest_SIVAMOORTHY_* , 17 Apr 2018 |
Teg Dehydration Stripping Gas Flow RateStarted by Guest_SidRah_* , 20 Aug 2025 |
Automatic Choke ValveStarted by Guest_Mudassssir011_* , 22 Jul 2025 |
